跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 700m 是 Dell 设计的一款超便携笔记本电脑。这款笔记本以其 12.1 英寸宽屏显示屏和轻量化设计而闻名,非常适合旅行和日常办公。 作者:Phillip Nguyen
Can I upgrade this old computer
I have a Dell Inspiron 700 m with Windows XP which is running well. However, as Windows XP is no longer supported I am afraid to connect it to the internet. Is there anyway to upgrade this computer so I can run a more current version of Windows which would allow me to add anti virus software to safely connect to the intranet? Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Thank you for the advice . I will check out the sites you recommended
由完成的
You can improve the 700m by using a dual band network card, The 2915abg is a
dual band NIC with a PCI plug and works good. it was used on an earlier model
and I dont why this NIC was never mentioned. I am intending to ask MKafee if
they have a package for windows xp to guard against problems while on the web.
由完成的
添加一条评论
3个答案
已选择的解决方案
@terrymcd biggest issue here will be the display driver. dell does not provide any approved ones for your model. There are work arounds so you could in thoery update to Win 7 at least. However you can upgrade your memory to max it out and also optimize your hard drive. Just because there is no longer support for Win XP does not mean you have to stop using it. You can get lots of anti virus for Win XP so you can safely connect online. Places like this and this one are a good start checking things out.
这个答案有帮助吗?
得分 3
添加一条评论
I would put linux on it, viruses won't be a problem, and it will run fast on old hardware.
这个答案有帮助吗?
得分 0
添加一条评论
you can add linux to your machine (but be aware: modern linux can have issues with your machine (I tried ubuntu, fedora and I got a lot of issues)
I decided to use open suse 12 (which works great)
note also that when installing the celeron chip do not display the PAE bit, so you must append this to the installer: forcepae
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Terry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 20
总计 1,743
