跳转到主内容
Sony Cyber-shot DSC-W5 5.1 Megapixel
Why is my telescoping lense stuck
i droped the camera and now the lense does not move out to take photos
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
You dropped the camera
causing the lens to jump or deform the guides that move the lens.
If under warranty see if it can be replaced... if not see if its worth fixing.
Generally these sorts of things are not DIY repairs
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
这个答案有帮助吗?
得分 1
添加一条评论
what happened when you dropped the camera is that the lens was open and has offset. what you need to do is force the lens to center and it will return to its chassis location and work. (happened to me)
这个答案有帮助吗?
得分 1
1条评论:
Thank you. Fixed my problem!
完成的
添加一条评论
A stuck lens happened to me twice - I dropped it twice!
After the first time I found a Sony service depot that told me it wasn't worth repairing, a $200 camera at the time (mine is a DSC-S600). I wasn't about to toss a Christmas gift from my kids!
I don't remember how I found them but twice now I've had the stuck lens fixed by "Home Electronics & Comm" at the Yorkgate Mall, northwest corner at Finch & Jane in Toronto, (416)665-5126. They repaired it for under $75 each time! Ask for Gohar.
这个答案有帮助吗?
得分 0
添加一条评论
How do you force the lens to centre?
这个答案有帮助吗?
得分 0
2条评论:
Simon, this is an old question and not to many people look in here. Your question appears like an answer. If you need some help with your camera, click on the link on the right side of this page "Ask a question" and give as much detail as possible, like what camera it is, what happened to it and what you have tried to fix it. Good Luck.
完成的
I did not drop but my lens got stuck Make sure batteries are good press on button and ok button at the same time and that fixed the problem
完成的
添加一条评论
添加你的答案
ml91401 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 4,793
