跳转到主内容
The Acer Aspire V5-571-6891 laptop is for personal or small business use and was released in 2012. It is mostly black with a centered, silver logo.
laptop work but blank screen
when i try to boot it up it starts but the screen stays blank what are the possible solutions??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Can you see any mouse or anything on the screen ?
It might be very dull so you might have to really look for it.
完成的
Hi,
Does the screen 'light up' or stay black? If it stays 'black' try shining a torch at an angle close to the screen and see if you can see the desktop display once it has booted up. If so it could be a backlighting problem.
Try connecting an external monitor and see if there is a display on it when you boot up.
完成的
添加一条评论
3个答案
已选择的解决方案
@tetzel , johann, Try hooking up an external monitor, if external monitor works probable laptop display issue, corrupt driver, bad connection on ribbon cable, bad display. If external monitor not working could be graphics card issue. Below link tells how to hook up external monitor to help trouble shoot your laptop, the 3rd link and other Acer forums on the net, addressing Blank/black screen talk about the Bios becomes corrupt and needing addressed. Good luck.
http://www.yumapk.com/how-to-connect-ace...
http://community.acer.com/t5/Legacy-Lapt...
http://www.tomsguide.com/answers/id-2221...
这个答案有帮助吗?
得分 4
添加一条评论
Take out the battery. Press power button for a minute. Then put battery back in again and power up. Repeat couple of times if necessary.
这个答案有帮助吗?
得分 2
添加一条评论
Possible that your memory needs to be re-seated
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
johann bayzil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 10,191
