跳转到主内容
加入维修社区 - 创建账户
HP Pavilion dv6000 的维修和故障排除信息,这是 HP Pavilion 系列中的一款 HP 笔记本电脑。于 2007 年 4 月发布。
Display is completely black
I have an HP Pavilion dv6000 and from yesterday the PC has restarted, but the screen remains completely black, why?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@piero90 connect an external monitor and let us know if that dispalys. This series laptop had issues with the GPU so the problem may be the logic board.
这个答案有帮助吗?
得分 2
6条评论:
If I connect a external monitor the PC functions.
由完成的 分享
In that case consider replacing the LCD. Use these guides HP Pavilion dv6000 for that
由完成的 分享
I have the same problem but mine dose not work with external display
由完成的 分享
I had same issues with HP laptops and fixed it also owned dv6000 once the solution to this is quite strange but not a permanent and 100 percent sure although it worked for me every time especially with HP with AMD processors, cover up your laptop with blanket and start up let the exhaust choke up and due to excessive heat there are some micro ( solder ) joints fix's up and you will get your display back running . I was amazed how it worked for me and I took a risk after researching alot, I have fixed couple of other HP laptops with this technical glitch please be careful you don't burn out the beds. Hope it works for you.
由完成的 分享
@chris7up " heat there are some micro ( solder ) joints fix's up " no system will heat up enough to fix any solder joints. The reason why this works temporarily at best, is related to the solder bumps with this poor processor design.
由完成的 分享
显示更多的1条评论
添加一条评论
添加你的答案
Piero Sabino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 537
