跳转到主内容
针对二十年间的Mac笔记本(iBook, PowerBook, MacBook, MacBook Pro和MacBook Air)的维修手册。
Probable bad hard drive
I have a Mac Book Mid 2012 and do not know the model number. I have experienced several issues which seem to indicate there may be hard drive problems. I have call support and been to the genius bar regarding my computer. When I shut it down at night within a 30 minute window it restarts. Web pages load slowly, When I did Command R for a recovery it never completed it just stopped on one of the last restarts. I have done NVRAM cleared the cache, used malware bytes done all the updates. It just all seems to return back to some subtle hard drive issue. Any help would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
First you should visit this site: EveryMac plug in your serial number it will tell you what your model is. To find your serial number you can find it in the About This Mac or on the bottom of your system.
We really need to have an idea what you have to help you.
完成的
Do you have access to a second Mac system which you can interconnect the systems (Target Mode)? If not do you have a bootable external drive (USB or Thunderbolt)? A 16 GB USB thumb drive will do.
完成的
添加一条评论
2个答案
已选择的解决方案
I believe Apple has now recognized the hard drive/IR cable issue on this model and is replacing them for free. They have not announced this program to the public as yet but my local ASP told me about it. If it is also a 15" model, ask them to also run the video test when you take it in.
这个答案有帮助吗?
得分 3
添加一条评论
If you use COMMAND + V you will boot in verbose mode. I suspect you will see errors reading the hard drive repeated, this would indicate SATA or Hard Drive. Since both are used to store the downloaded Internet Recovery it would be effected.
You should get a thumbdrive as Dan suggests to isolate that set of devices from the boot process.
You could also hold down D and see if diagnostics come up. If so run the tests.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Charles Joy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 93
