跳转到主内容
Repair guides and support for headphones inserted into the ear or ear canal, also known as earbuds, earpods and earphones.
20 个问题 查看全部
Volume buttons not working Bose qc20i
How i can open the microphone and control buttons case from a Bose qc20i headphones?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
Are you using these on a desktop (Tower computer), mobile phone (Smartphone) or Tablet (iPad for example)?
All 3 specified above except desktop / laptop should have volume control functionality from the headphones. On rare cases some headphones require an application which is usually specified in the user manual that comes with the headphones.
完成的
I'm using this with iphone and they are 1.5 years old. The buttons finally died and I want to fix it.
完成的
Hello!
My Bose QC20 has the same issue with the control button. Did you find out how to repair it?
完成的
any updates guys? same issue on my end.
完成的
check if the headphone jack is not blocked by any lint or fluff. Scrape all the lint out of the socket to make the remotecontrol work again (did it for me)
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
@modjo, Laurentiu, Saulail, open the microphone and control buttons case on a set of earbuds/ear phones. The case will probably either snap open using a blunt thin blade(guitar pick) prying at the seam or if molded/glued, you will have to very carefully(not to damage board or controls) use a sharp blade/razor knife to cut open along the molded seam. This will gain access to see if wires broke from board,etc. Links below to show the 2 methods. Good luck.
Apple EarPods Teardown
https://www.youtube.com/watch?v=-w6K6kDK...
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Laurentiu Olteanu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 11,943
