跳转到主内容
加入维修社区 - 创建账户
Behringer Eurolive B212D 扬声器系统的设备与维修信息。
The unit will not power up...
The unit will not power up...when I press the power on button the lights kind of flash/flicker and then nothing. It just started doing this all of a sudden...any ideas or suggestion so I can get this unit functioning again?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
6条评论
The lights do not flicker every time. When they do flicker I can hear a noise hum. The guide did help me take it apart, but I did not see any thing that looked unordinary. I thought it may be the power switch...I will post some photos later...thank you
由完成的 分享
данная проблема характерна для всех колонок этой серии! причина в износе электролитических конденсаторов вторичных цепей импульсного блока питания. ремонт - замена (желательно всех) конденсаторов.
!!!надо правильно выбрать марку конденсаторов, иначе сделаете хуже
Google translation:
This problem is typical for all columns of this series! reason for the deterioration of the electrolytic capacitors of the secondary circuits of the switching power supply. repair - replacement (preferably all) of capacitors. !!! it is necessary to choose the brand of capacitors, otherwise make worse
由完成的 分享
Hey guys. I've left my two 212Ds in the garage now for about a year cause I was broke and couldn't but the replacement part supply. Looking at the PCB, one of the smaller caps was definitely bulging and I got into electronics just enough to be dangerous… When I finally got the courage to replace the bad caps myself, I couldn't for the life of me melt the solder on the board! Is it just my cheap Chinese made soldering iron, or is the board somehow protected to prevent a relative noob like me destroying a PCB? (Which is busted anyway, so may as well give it a try, right?)
Related question: Does the brand of capacitor matter much? I'd like to go with something higher quality than what's already in there… Panasonic maybe? This only matters if I can melt that dang solder! (My iron claims to go upward of 450, so I assumed it'd be fine. It worked on all my other small projects (thanks radio shack!)
由完成的 分享
Hi Eddie Ludema
I think is more on the wattage your soldering can give out.... IIRC min 60W, best I heard is ard 80W is good. To desolder add some new solder over to it, to have some flux, it does help to melt and use a desoldering pump to remove it.
由完成的 分享
I have been soldering since I was 9yo, it's not something that anyone will be good at without some practice.
You need to get the solder to flow, to conduct the heat from the iron. I also wouldn't recommend using an Iron that is not temperature controlled, if you don't know what temperature your iron is how are you going to know if it is going to melt solder or burn the crap out of the PCB
Perhaps practice on some boards that don't matter, removing and installing components, Personally I prefer de-soldering wick over the sucker pump, although they do have their place.
由完成的 分享
显示更多的1条评论
添加一条评论
4个答案
已选择的解决方案
@jakeboger sounds like you are having a power supply issue. Possibly bad caps based on the flickering lights. You'll have to disassemble the unit. Use this guide and take a look at the components. Check for leaking or domed looking caps etc. Post some images using this guide so we can see what you see.
Behringer Eurolive B212D 电源 PCB图片
指南
Behringer Eurolive B212D 电源 PCB 更换
难度:
中等
30 - 45 minutes
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 2
1条评论:
I have B112D similar problem, what power supply parts can I buy? I tried to find Behringer Q04-AWT00-17000 Power Supply PCB For EUROPOWER B112D in Australia, don't seem to get any answwr.
由完成的 分享
添加一条评论
最有帮助的答案
I fixed a Behringer BD212D which did not powered up recently: here are some clues.
Diagnostic: 16V DC supply not functional due to unreliable design and poor quality components…
1) Schematics: Look for Eurolive BD215D schematics, they are almost identicals.
2) Disassemble the unit following available tutorials. Take pictures, count your screws !
3) I had to replace IC3 (Viper22A available on Digikey as #497-7594-5-ND)
4) I also replaced also C10 (replace with 47 uF, 35V), C2 (replace with 100uF, 35V) and D37 (replace with 800V,1.5A) diode.
5) Reassembled everything, thanks to pictures.
6) Power-up ok, tested ok
这个答案有帮助吗?
得分 3
4条评论:
How did you figure out these parts were bad? Cheers
由完成的 分享
They were parts of an auxiliary power circuit that is supposed to feed the rest of the circuit board. When power was applied at the circuit input, no output was provided. I replaced the parts of this circuit which were the most susceptible to failure, one at a time. Designwise, some of them have specifications which barely meet the requirement for this type of circuit... the diode D37 failed short and probably damaged the other parts.
由完成的 分享
Someone can help some way B112D no power
由完成的 分享
"3) I had to replace IC3 (Viper22A available on Digikey as #497-7594-5-ND)"
Did you mean "IC6"? I couldn't find IC3 on the schematics. Also did you mean #497-7694-5-ND?
https://www.digikey.com/en/products/deta...
由完成的 分享
添加一条评论
Hope this posts. I have cured a few of these units with capacitor replacement. Not the big ones the small 10, 47 and 100 uf in primary side . May or may not show as bulging at the top. Also had to resolder c33 yellow rectangular mylar cap in primary side on one occasion. This is for 615d ps/amp pcb. Have also had broken pins on output ic due to flexing and vibration in this area.
这个答案有帮助吗?
得分 1
1条评论:
Hey Pesh. My 115d bit it last week and i came across this thread and after reading your post i opened it up and found one cap a little bulgy 1 of the 100uf looks like it drives the secondary brd as there is two lines of the ribbon that feeds top pcb comming from right next to it on main board. getting a replacement tomoz fingers crossed. Cheers :)
由完成的 分享
添加一条评论
Good good day,
Is there anywhere I can purchase this B212D power supply?
这个答案有帮助吗?
得分 0
3条评论:
same question where can i purchase one from?/
由完成的 分享
Same problem just tried to power up my B115W speakers both of them dead. Sitting in the garage for about a year
由完成的 分享
I have the same problem with my 2 B215D speakers and my behringer subwoofer
由完成的 分享
添加一条评论
添加你的答案
Jake Boger 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 44
过去 30 天: 122
总计 25,759
