跳转到主内容
加入维修社区 - 创建账户
有关三星 2013 年发布的 60 英寸 LED 高清电视(型号 UN60FH6003FXZA)的设备与维修信息。
Back light dark on top
Dark the top is black
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
@duba is it just darker or is it black? do you still see things on that part of the screen?
由完成的
I have the same problem, my screen is dark in the top.
由完成的
I have a similar problem but I have no image or sound it just blinks now on and off and the top of the tv is darker then the bottom I replaced the power board and the main board and still no fix need any tips!
由完成的
I have the same problem. it started gradually getting worse now to the point the top is virtually un-viewable with the darkest at the top fading back to normal at the bottom. there is three cards in the back, has to be one of them i would think.
由完成的
@georgesl not necessarily. Could be the LED strip that makes up your backlight. Repairable by disassembling the panel itself and hopefully getting an LED replacement
由完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
@dube @lintaum this is most likely caused by a failed backlight. Could be the power board, the LCD or the inverter circuitry. This is a vague answer due to the fact that we do not have all the information.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Portia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 27
总计 4,670
