跳转到主内容
加入维修社区 - 创建账户
FoodSaver 推出的最新款真空密封机,于 2015 年底发布。包含附件软管、PulseVac 按钮以及根据食物质地设置的多种模式。
How do I remove the dip tray?
The dip tray is full. How do I remove it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
As shown on our troubleshooting page, on the bottom front edge of the machine, pull on the handle to pull out the dip tray. Then, you will see where the liquid is stored. Carefully take out the tray and rinse it. Before putting it back into place, ensure that it is completely dry. Your FoodSaver should now vacuum the air out of a bag.
这个答案有帮助吗?
得分 1
6条评论:
How do you take out the tray. It doesn't lift out,
由完成的
Same here! They must have forgot to put the "gray release buttons "on
由完成的
Same problem! Anybody find a way to clean the tray?
由完成的
Same problem!! Can't find any info on the internet
Nov 20, 2023 by tcruz
由完成的
I had the same problem with my V5860 - then I found 2 levers on the underside of the machine which had to be pressed in while pulling on the tray.
By doing that, the tray slid out.
Good luck!
由完成的
显示更多的1条评论
添加一条评论
添加你的答案
Matt Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 66
总计 10,533
