跳转到主内容
加入维修社区 - 创建账户
Canon PIXMA iP4700 彩色喷墨照片打印机的维修信息。发布于 2010 年。型号:iP4700。
canon IP 4700 PROBLEM
coming out code 5B00
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
william error code 5B00 defines the error as "Ink Absorber full" which of course means that the ink absorber is
supposed to be full. solution for that is
1) Ink absorber condition
2) Part replacement:
- Ink absorber kit
3) Ink absorber counter value in theEEPROM;
reset the ink absorber counter.
这个答案有帮助吗?
得分 4
2条评论:
The last step however, apparently involves sacrificing your firstborn to the Daemons of Teh Intarwebs, invoking Cthulhu, Hastur & Nyarlathotep, and so forth ;-)
由完成的
@flyingdutchman it sure does appear that way ;-). I am amazed by the complexity of printer repairs. I bet those are probably the most discarded pieces of electronic equipment. PITA to fix, even with manuals :-)
由完成的
添加一条评论
With the mistake your printer is encountering, please kill the printer, unplug the force rope from the back and forget it for no less than 10 minutes, then connect it back to and walk out on. On the off chance that despite everything you encounter the same issue, the printer will shockingly oblige adjusting to determine the issue.
这个答案有帮助吗?
得分 0
添加一条评论
I have a IP6820 that has quit after a 2-year life-span. A Canon technician, after I described the problem, declared the printer irreparable. I’m not convinced. I suspect it is a sensor. But how do you get and replace a sensor?
gtdiller@ufl.edu
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
william 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 31
总计 3,754
