跳转到主内容
加入维修社区 - 创建账户
飞利浦便携式 DVD 播放机,型号 PD9000/37,于 2011 年制造。
Volume control not working
Sound is working through the speaker but it's stuck on maximum volume. Turned the volume wheel but volume won't change. Bought used, so I don't have the remote or manual. Is there a way to fix it? Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Here is a link to the User Guide for your player.
http://download.p4c.philips.com/files/p/...
If you are trying to use the Volume control on the side of the player (p.13 of the manual) to adjust the sound level and it is not responding, it may be that the control is faulty or perhaps there may be a wiring or component connection problem
Here is a link to the Ifixit guide on how to open the player so as to gain access to the inside of the player and then to the volume control, which should be able to be seen at about Step 3 in the link below, so that you can ascertain what the problem is.
Philips PD9000 37 按键更换
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much! I will try the suggestions with success hopefully and follow up :)
-Gina
由完成的 分享
添加一条评论
添加你的答案
Gina Aguilar 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 31
总计 6,735
