跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
How to bypass the iPad passcode
Hello everyone! My grandmother just got an iPad recently and managed to put a passcode on it and not remember what the passcode is. I have tried putting the iPad into recovery mode and restoring it. However, there is an error every time I try to do this. In addition, I have tried using icloud. To erase the iPad, you need wifi and she has disabled it by trying her passcode to the point where it says "connect to itunes" like it is permanently disabled. PLEASE HELP!!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
do i need to have an internet connection while doing this action and connect to the PC?
完成的
添加一条评论
6个答案
最有帮助的答案
While you try to restore the I-pad, Take it to DFU mode and try to restore it.
DFU Mode: Press the Power button and Home Button at the same time till screen goes off,
After 5 secs of doing that, leave the power button and just press the home button till
it goes to DFU mode. After that, try to restore the I-Pad
Hope it Works.
这个答案有帮助吗?
得分 2
添加一条评论
Follow what Patrick said, make sure the iPad is DFU mode otherwise it will not work. Make sure you are using an original apple charging cord, if it doesn't work the first time try another charging cord or computer, sometime your settings on the computer will prevent the new software from going into the iPad properly.
这个答案有帮助吗?
得分 1
添加一条评论
There is a "what" error when you try to restore?
Be specific enough please.
这个答案有帮助吗?
得分 0
添加一条评论
A program named 4uKey works for that issue.
bypass ipad passcode in 1 click.
这个答案有帮助吗?
得分 0
1条评论:
Can the program bring peace to the world in one click too ?
完成的
添加一条评论
If you wish on a star you can do anything in one click.
这个答案有帮助吗?
得分 0
添加一条评论
In such a situation, you can try an iPad passcode unlocker to help you. There are many such tools online. I have ever used one called Joyoshare iPasscode Unlocker to factory reset my locked iPad. It is easy to use. Of course, you can google this kind of unlocking tool and choose one that you desire.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
morganmachado1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 5,039
