跳转到主内容
加入维修社区 - 创建账户
一款单手出杯的 12 杯可编程咖啡机,带有隔热储罐和加热器。该产品由 Hamilton Beach 生产,于 2008 年 12 月 15 日发布。
Why does my coffee taste bad?
My coffee usually tastes good. Recently though, my coffee has tasted worse and the coffee grounds are kind of gritty in the coffee. What should I do to correct this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Have you changed anything? Where do you get your water?
由完成的
添加一条评论
3个答案
最有帮助的答案
If your coffee is tasting bad, it could be a result of poor water quality, incorrect coffee to water ratio, the coffee grounds are either too fine or too coarse, or the coffee maker might be dirty. Solutions to these issues can be found in the Hamilton Beach 48464 Troubleshooting page.
这个答案有帮助吗?
得分 1
添加一条评论
There are some another serious reason for your coffee is tasted bad. If you don’t clean your coffee machine regularly then your machine make a bad effect to your coffee flavor. The coffee flavor with smell and drinking bad. So you must need to clean your machine every 2 days of 3 days.
Or if your coffee bean is grinned with high speed then it can create a bad flavor taste.
这个答案有帮助吗?
得分 1
添加一条评论
You can let straight vinegar sit in the tank overnight. Believe it or not, it might fix a whole lot of taste issues.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Damico 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 14
总计 1,887
