跳转到主内容
Sony’s 20.1 megapixel camera designed to capture still images and video recording. Model number: DSC-W800.
Why will my device not power on?
Why won't my Sony Cyber-shot DSC-W800 power on? When pressing the power button nothing displays on the screen and the device seems to be unresponsive.
Could this be a battery issue or something more serious that would require repair?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
يرجى توضيح أكثر هذا قليلا
完成的
@tcampo what happens when you do replace the batteries? does it then turn on?
完成的
添加一条评论
1个答案
已选择的解决方案
There may be several reasons why your device may not be powering on. Following are the common ones:
  • The battery may not be sufficiently charged. It may discharge automatically if not used over a long period of time. In this case, simply charge the battery. Also, check to make that the battery is inserted in correct orientation.
  • The battery terminal may not be clean. You may clean the terminal with microfiber.
  • External temperature also effects the way the camera functions. Thus, make sure to not use the camera when the temperature is above or below 0-40° C. Condensation might occur if the camera is moved from extremely cold temperature to a warm environment, which could prevent the camera from functioning properly. In that case, let it come to room temperature and allow the condensation to evaporate naturally.
  • For more information, refer to the troubleshooting page.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Thomas Campo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,545
