跳转到主内容
加入维修社区 - 创建账户
4.3 英寸宽屏 LCD 显示屏,搭载 333 MHz 处理器。型号为 PSP98510。维修此设备需要用到常见的螺丝刀和撬棒工具。
PSP 2000 battery external charging
Can you help me my PSP 2000 can't detect any type of battery
I have the original battery but I think it died already, because it's old, when i plug the original battery it just blink orange light then green light, alternate then the orange light will be gone.
My psp only turns on when plugged in via charger, I tried using other psp batteries (brand new class a) so I plugged in the battery, it has the orange light a sign of charging but still it won't recognize by psp, the battery information says (battery external) and the other information are blank
I can use my psp/play games when plugged-in via charger no other problems except the detecting of the battery.
PSP 2000 japanese model
5.50 Prome-4
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Hi Nikko,
I've got the same issue. If you confirm that the battery you are referring to works on other PSPs, you may follow the link below. Hopefully we'll find a solution ;)
PSP working with power supply but functioning batteries not detected
这个答案有帮助吗?
得分 0
添加一条评论
Nikko Mallari check the “Charging Fuse” If it does not show continuity and may need to be replaced, your battery won’t be found. Also check for bad traces on your circuit board as well as burned, loose or missing components around the power IC. To check it out use this SM with all the schematics you will need Psp-2000-Service-Manual.pdf
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nikko Mallari 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 22
总计 1,105
