跳转到主内容
加入维修社区 - 创建账户
Inspiron 15-3521 配有可选触摸屏功能,并配备 15.6 英寸显示屏。这款笔记本电脑还拥有哑光表面,以及带有数字小键盘的键盘。
No Boot Device Found
Just replaced my hard drive with a new one from ifixit, when running diagnostics it now shows no errors when previously it said there was a problem with the hard drive. On boot up it states: No Boot Device Found. Press any key to reboot machine
On the boot menu after pressing F2, I only have the following options:
LEGACY BOOT: (which is gray)
UEFI BOOT:
When selecting UEFI BOOT:
UEFI Onboard LAN IPv4
UEFI Onboard LAN IPv6
It doesn't seem to matter which order they are in
After reading all other forums, I have not found a solution to this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
did you format your drive re-install your Operating system on the new hard drive? When you boot to BIOS check if the hard drive is getting detected there or not. Here are the steps:
Restart the system and immediately start tapping the 'F2' key to enter the 'BIOS'.
Please check what is written next to 'Fixed HDD'.
Double check your installation and your drives compatibility
这个答案有帮助吗?
得分 2
添加一条评论
So if I enter f2 and enter bio what next, because my dell is still on fixed HDD ( not detected) . What should I do next?
这个答案有帮助吗?
得分 0
1条评论:
tucrkilerita what is your computers make and model? This is a new hard drive?
由完成的
添加一条评论
添加你的答案
Karen Chandler 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 15,382
