Display blink, problem with intel graphic driver
I try update to new driver, i try roll back old driver, but display still blinking. Only work when graphic card is disabled, but then brightness control dont work, and battery life is only 30 mins. Any fix?
Everyone says is only driver? If conctor is broken, display will not work when i disable drivers?!
由 nastic 完成的
nastic, exactly what do you mean by blinking? Does it do it all the time? It stops blinking when you disable the graphic card? How do you do that? What do you get when you connect an external monitor?
由 oldturkey03 完成的
does the problem happen when the battery is connected? I would look for info on how to do a power flush on the laptop, I'm looking but can't find anything. this has fixed issues like this for Dell machines in my experience.
Sony Vaio Fit 13A Troubleshooting
由 techpj 完成的
@oldturkey03 i just disable from device manager. Its happend in both ways, on battery or cable
由 nastic 完成的
This is exactly what i am experiencing now, did you find any solutions?
由 Alfonce 完成的
