Is it possible to check the speaker internally?
I would love to see inside it. Many people have purchased this model. thank you
See inside as in open it up? I had to open mine up because I dropped it and I wouldn't recommended it. The item is non-repairable as stated from manufacturer, and if you open it up like I did, you won't be able to close the casing as tightly as in original condition (I presume the waterproof tolerance has been affected because of this). There is some glue underneath the casing so I suspect this helped hold it in place.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 1,693
