跳转到主内容
Samsung's second-generation smartwatch, released in April 2014 and powered by a Tizen-based OS. Model Number:SM-R380.
Battery will not charge
My Samsung gear 2 want charge..It's not the battery but the part on the watch the 5 little gold dots. One of the is worn. Can that be fixed or replaced..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
need to be fixed
完成的
添加一条评论
1个答案
i had one of mine worn down to not charging. I put a dollop of solder onto the pad, and it started charging.
however, there is a possability that there is a disconnect inside it as well. in which case, a replacement component, or jumper may be needed
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mcromartie17 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 270
