跳转到主内容
加入维修社区 - 创建账户
Philips Saeco Intuita 浓缩咖啡机的维修信息。
removal of outside covers
Internal problems, Something is either plugged or jammed as no water comes through the brew head, and a wiff of smoke from the vents! I need to take this apart but am not familiar with Saeco, much used to Delonghi machines.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Hi,
Hopefully this video about entering test mode will be of some help. At least to tell you what might be wrong. Apologies if you already know this. https://www.youtube.com/watch?v=I-52zNyT...
完成的
thank you! just from sounds in your video, think it's the motor or brew group. Will try it this aft! Pete Watson
完成的
Pete Watson any chance you can post an image of what your espresso maker looks like? I have a couple of manuals but need to verify that I have the right model.
完成的
添加一条评论
1个答案
最有帮助的答案
Pete Watson I only have the philips_saeco_hd8750_hd8751_hd8752_espre.pdf parts manual for that one. The difference here is the front panel, but as you can see from the parts manual, the rest of the machine is still the same.
这个答案有帮助吗?
得分 3
1条评论:
this is great! Thank you! I found out that my pump is the culprit, and am replacing it with one from a Delonghi that I have for parts!
完成的
添加一条评论
添加你的答案
Pete Watson 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 21
总计 3,103
