跳转到主内容
The JBL Charge 2+ made by JBL is the second generation of the JBL Charge brand.
20 个问题 查看全部
Why is power button dosen't work?
the "power button" is on, but the device is not working or charging. what should i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
最有帮助的答案
nikookhadem, "the device is not working or charging" sounds like you have a power issue. I would start with the battery but make sure that your charging port is in good working condition.
这个答案有帮助吗?
得分 3
2条评论:
it is brand new! i just used it 3 times. I don't know but i'll check it anuway
完成的
If it is, I would most certainly try and have this fixed under warranty.
完成的
添加一条评论
添加你的答案
nikookhadem 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 5
总计 1,576
