跳转到主内容
主板和 CPU 维修指南。
Where to buy replacement CPU socket?
Greetings,
Where can I buy a replacement CPU socket? I have searched and searched and only been able to find one store on eBay in China. Anyone know a place in the US?
www.ebay.com/itm/Original-New-Foxconn-H2-Socket-LGA1155-CPU-Base-PC-Connector-BGA-Base-/231098753262
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
"Charles, if you can find one, how would you solder the hundred + connections?"
You do not solder. You heat the socket with heat gun to melt solder balls.
完成的
Would be better to buy another motherboard.
完成的
Im bga certified, I just need the part
完成的
EBay and how much to fix my motherboard same problem jandersen
完成的
添加一条评论
2个答案
已选择的解决方案
Charles all searches came up Shipping from China/Hong Kong/Taiwan to worldwide (7 to 19 business days) for the replacement CPU socket Foxconn-H2-Socket-LGA1155-CPU-Base-PC-Connector-BGA-Base-/231098753262. It may be worth trying to place the order on Ebay for the price of part $3.59 and shipping $3.30.
Good luck with the part and installation.
http://www.ebay.com/itm/Original-New-Fox...
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
这个答案有帮助吗?
得分 2
4条评论:
They come with solder on the grid. You use heat gun.
完成的
Or you can BGA Reflow them if you have the balls and stencil
完成的
You just added a clean socket. No solder on it to reflow.
完成的
@mayer sounds like robert is referring to a reball. Solder balls and stencil combined with a rework station can accomplish this task.
完成的
添加一条评论
添加你的答案
Charles Kensington 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 8,568
