跳转到主内容
加入维修社区 - 创建账户
这款笔记本电脑发布于 2012 年,配备 Core i7 处理器、独立 Nvidia 620M 显卡和 1080p 电子显示屏。
Thread size of screws on bottom of computer?
What is the thread size of the screws on the bottom of the computer (there are 12 of them)? I only have half of them left and would like to purchase screws to replace them (I called Asus and they were not able o give me the information)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
There are eleven screws. Nine have a Torx 5 head and two have a philips head. I too am missing a couple screws. I also spoke directly with ASUS and they could not even tell me. %#*@, they make the things and cannot tell me what screws they use! Very poor. Perhaps some fab makes the systems for them. That is very common in the industry: Dell and HP use a fab, likely the same one.
由完成的
添加一条评论
3个答案
已选择的解决方案
nadia, those are M2 (metric 2 mm screws) X 2.5mm length T5 screws.
这个答案有帮助吗?
得分 3
2条评论:
salut vous avez ce site https://www.asusparts.eu il suffit de donner la marque le modèle ou ici aussi https://www.zandparts.com/en/
由完成的
I believe, and measured, M2 x 3.5mm
由完成的
添加一条评论
Do they look like this? (Source)
It lists it as "M2*2.5L+0.5(3,0.3)(K)T5" on the parts site. I noticed it said T5, and the twelve screws are T-5 torx screws.
To be quite honest, I can't really determine what the thread size is based on that string of mumbo-jumbo, but it does look like measurements. The teardown does mention that these screws are not proprietary, so they should be readily available somewhere.
For what it's worth, I hope this at least helps point you in the right direction!
这个答案有帮助吗?
得分 2
1条评论:
Hi M2*2.5L+0.5(3,0.3)(K)T5
m2 is the thread
2.5L is 2.5mm thread length
0.5 is o.5mm for head thickness
3 is 3mm head diameter
t5 is the drive type
hope this helps
you can find similar screws on laptopscrewdirect.com
they sell m2x3mm-t5 which will fit just fine
由完成的
添加一条评论
I actually got some free samples of these from https://www.vital-parts.co.uk/m2-x-3mm-t...
Different torx size in that its T6 but didn't really make any difference to me and I got them free (had to pretend I needed a few more...)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nadia 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 51
总计 31,951
