跳转到主内容
The Canon PowerShot is a 5.0 megapixel camera with 4x opitical zoom.
Camera will not work
When I turn the power on I get a reading on the screen that says "memory card error" and will not take a picture. Have tried a new SD card. Nothing helps.;
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
**Answering for completion**
This often happens due to the use of an SDHC/XC card - these are not supported due to the SD card controller in these cameras just being too old. The camera isn’t broken, and this error is very much expected.
You need a non-HC card, which are difficult to find now since HC/XC cards work in just about everything today. That said, the non XC capable devices are still easy to get cards for since HC is still very much a current spec. You can usually find these cards on sites like eBay used (be warned a lot of these cards have a ton of write cycles and will not last very long before showing signs of failure!), NOS or a new Chinese made card (more failure prone then a good name brand, but your best bet for cameras like this). Anything larger then 2GB is usually HC today due to volume cost making 4GB SD non-HC cards obsolete. Newegg has one, but there are no more “name brand” 4GB cards of the non-HC spec.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rerick2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 37
总计 1,310
