跳转到主内容
加入维修社区 - 创建账户
Acer Aspire 8920 是 Acer, Inc. 于 2008 年发布的一系列笔记本电脑。Acer 是一家总部位于中国台湾新北市的电子公司。8920 机型作为 Gemstone 系列的一部分发布,是 Acer 生产的首款配备 18.4 英寸屏幕的笔记本电脑。
Display is not working
Hello,
after I start my laptop the load-screen is shown for about 10 sec after this the screen turns black. I know the laptop is still working and Windows is loading but without any graphic.
When I connect the laptop with an external Display, it works and I see the desktop external. This means the graphic card works but the laptop-display stays black. When I push the function button with f6 the lightning button the screen appears for some seconds on the laptop-screen and again nothing. What could be the Problem?
Thanks in advance.
Regards
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
the screen resolution iss to hight connect it to an external monitor and change the laptop resolution to 1024 resolution and it will work ..thats it
由完成的 分享
Ik heb de Acer Aspire 8920G uit 2008.. een oudje dus..maar werkt nog goed
Update gedaan met cpu en gpu Nvidia GeForce 9600 GT,maar blijkbaar blijkt deze videokaart niet direct compatibel met het moederbord..het scherm blijft zwart.
Heeft te maken met V-RAM..maar dat is andere koek..enig idee hoe dit compatibel gemaakt kan worden?
由完成的 分享
添加一条评论
3个答案
已选择的解决方案
YET, sounds like a backlight issue. This could be related to the screen or the inverter. I would start with a new inverter. Relatively inexpensive and not very difficult to change. Thsi video will give you an idea of what you are looking at.
这个答案有帮助吗?
得分 2
1条评论:
Thank you oldturkey03. I will change the inverter in a few days. After this I will come back. :D
由完成的 分享
添加一条评论
I changed the inverter and the problem is still there. Now Im sure it should be the screen itself.
Thank You.
这个答案有帮助吗?
得分 0
添加一条评论
I had same problem on my Aspire 8920g in 2013. Just want to share my solution.
oldturkey03 is right that the problem is with backlight.
I solved it in two steps. Starting with easiest.
First - replace inverter, in my case the problem was still there, but for some users it can be solution.
Second - replace LCD CCFL Backlight. This step is more difficult, but with patience and skilled hand it is less than 2 hour job. To change CCFL is cheaper than whole screen.
You can find them for under $20, just search eBay for "LCD CCFL Backlight Aspire 8920",
example eBay link
I did this repair in 2013 and still PC is working without problems.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
YET 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 18
总计 3,719
