跳转到主内容
加入维修社区 - 创建账户
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
The horn does not work
the horn does not work
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
fuse is not blown but horn still does not work
完成的
what else could possibly wrong with the horn
完成的
添加一条评论
4个答案
已选择的解决方案
Sam Mazzolino, could be a horn issue as well as a blown fuse, the horn relay or even the horn button itself. First check the fuse. Make sure that it is good. Then apply 12 volts to the horn directly and listen if it works. Some instructions on here If it does, you know you are having a power issue. Check the relay next. For more information about the relay location etc. We'd need to have the exact year of your Corolla.
这个答案有帮助吗?
得分 2
1条评论:
my car is 2006 toyota corolla
完成的
添加一条评论
I normaly only work on domestic autos however this is simple. Check your owners manule for the locations of all fuse banks. Next look for any fuse related to your horn. Check each one for a bowen fuse(burnt center seperated metal strip). Replace with like fuse I.E. 20 with 20. Note do not replace with greater or lesser fuse, you will damage your electrical system. If all is well an no horn then compleatly disconect the batery for three minuts an reconect snug. If still no horn run a code reader to see if the car tosses a horn code. If no horn, fuse problem, and or code take it to a Toyota delership, this should be fixed for free or up to no more than $199.00. I know you should go directly to a code reader however not all of us are rich enuf to buy one or to go right to the dealer. This is the best way to go about any auto problem before flushing away your bank acount. I hope this helps.
这个答案有帮助吗?
得分 1
添加一条评论
My Toyota Corolla verso diesel 2008 car's horn is not working please tell me how I can fix it myself. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
If the fuse is good and the horn it self is good, then it should be from the horn and srs connection under steering
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam Mazzolino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 60
总计 21,485
