跳转到主内容
加入维修社区 - 创建账户
Gateway MS2285 是一款属于 Gateway NV53 系列的笔记本电脑。其主要配置包括 AMD 处理器、15.6 英寸显示屏以及 4 GB 内存。
Computer powers on but no display
My computer seems to power on but nothing shows on the display.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
Nothing works I took the battery out power supply and held the on button for one minute still did not wok or come on
由完成的
@brucec2
What is the model number of the laptop if not the one shown on this page?
Does it show that it is charging when the charger is connected to it?
由完成的
yes it is but black screen
由完成的
@brucec2
What is the model number of the laptop,?
Does it boot into Windows but without a screen, i.e. is there a HDD activity light that turns on etc?
Try shining a torch at an angle close to the screen when the laptop is on to check if you can detect any images at all as it may be a screen backlight problem. They will be very faint if they are there
Try connecting an external monitor to the laptop and check if there is a display on it. Don't forget to press the appropriate functions keys to connect the external display.
由完成的
添加一条评论
2个答案
已选择的解决方案
David Michaels, use an external display and see if it does display. If it does you most likely have an issue with you LCD. If it does not, it could be cause by a bad HDD , a bad motherboard or a bad BIOS. Remove the memory, the battery and the power supply. Hold the power button down for 30 seconds. then reinstall the minimum amount of memory and the power supply. Try a restart. If not then remove the memory and powering up the notebook to see if you get any error beeps. Let us know if you get anything. See if you can access your BIOS by pressing either the F1, F2, the ESC or F10 key while the Gateway is in the startup process. If you can see your boot option, set it to optical drive and insert a bootable disk. See if that brings the display back.
这个答案有帮助吗?
得分 2
2条评论:
How do you remove the memory on a gateway
由完成的
@Patrick Sidoti
What is the model number of the computer?
由完成的
添加一条评论
I've got a gateway NV53A that does the same thing. No vedio when I turn in on. Then I remembered a tech trick from training. Press F1 to drain the bios and then press the power button. Now I have desktop. But I still have to press F1 every time I boot. So I'm guessing I need a bios update.
这个答案有帮助吗?
得分 1
1条评论:
This worked for me, F1 plus power. Thanks
由完成的
添加一条评论
添加你的答案
David Michaels 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 67
总计 12,064
