跳转到主内容
加入维修社区 - 创建账户
HP Chromebook 14 是 Google Chromebook 系列的一款变体机型,于 2013 年 9 月 11 日发布。型号为 14-Q010DX。
Battery replacement - will this fix the problem?
This Chromebook battery will not charge (stuck at 12%). "battery_test 1" indicates battery is good. I am concerned if I spend $75 on a replacement battery on a $200 Chromebook it still may not fix the problem. Is this a known issue that is easily fixed with battery swap? If so, I might continue with the purchase. Model: 14-q063cl
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
If the laptop is out of warranty you are right to be concerned about the cost. My personal opinion is to offload the faulty laptop and buy a new one. Chromebooks are so cheap nowadays one COULD just buy a new one every time it fails when it is out of warranty.
完成的
添加一条评论
1个答案
已选择的解决方案
Just an idea. If the test indicates “good” try carefully disconnecting the battery and discharging power by holding down the power button for 30 seconds and then reconnect and switch on. Any help?
How to disconnect battery:
HP Chromebook 14-Q010DX 电池更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kurt Dreher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 433
