跳转到主内容
加入维修社区 - 创建账户
三星 Galaxy Tab S 10.5 发布于 2014 年 7 月,是一款 10.5 英寸安卓平板电脑,分辨率为 2560x1600 像素,配备 16GB 存储空间和 800 万像素摄像头。 型号:SM-T800 (WIFI 版),SM-T805 (蜂窝网络和 WIFI 版)
LCD replacement half screen
I have a Samsung Galaxy tab s 10.5 SM-T807R4 with Half screen half side of the screen works well and the other side white with multi line
the touch screen function works well in both sides
this looks like this link for another tablet
http://www.slatedroid.com/topic/37131-dr...
i think i need to replace the LCD.
the screen has no cracks looks good
is there a video or some guide i can follow to do the repair ?
please help me out
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
It can be also a flex cable or flex cable connector problem. So check them before buy replacment display.
Some times flex just slides a litle bit out from connector causes problem like this.
If a tablet was droped or bended than lcd control board and lcd connection flex can be damaged or lcd glass edge cracks causing the problem. This you can not see from outside or just removing back. Anyway in this case you need new display assembly which comes glued with midle frame and home button, so just move board and other staf from old to new and that it. Do not buy just display without frame from china guys because the price is almost the same and you will need to glue it with frame in correct position. One mistake can damage new display.
这个答案有帮助吗?
得分 1
1条评论:
Hello Lito771.
Unfortunatly for me, I bought the display assembly from china guys, without the frame, as I didn't noticed the difference, and also because no one else had it in stock anyway. So I need to separate the frame from tablet from the broken screen first, and then glue it to the new digitizer. Is there any tutorial or instructions about how to do it ?
由完成的
添加一条评论
matrix, looking at your attached image you are right. you will need a new LCD.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
matrix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 2,032
