跳转到主内容
加入维修社区 - 创建账户
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
How fix bent something inside card reader?
I watched inside card reader.
then I saw bent something.(just one)
Is that not right?
Everything staight up to bottom
but just one is left to right.
Do I have to replace or remove it?
Thank you!
I'm waiting for answer :-)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
已选择的解决方案
if you know how to solder. you can replace it with this..
http://www.dealextreme.com/details.dx/sk...
这个答案有帮助吗?
得分 1
2条评论:
Thank you. It will help for me.
由完成的 分享
ok, i have to accept that you changed your mind and accepted his answer.....
由完成的 分享
添加一条评论
最有帮助的答案
ok, i was right.
it was not necessary to open a new question for that. but you can close the othere one by accepting the answer there.
the card readers are very weak - surely you could try to bend the wire back - but it will most likely break.
replacing the card reader is the only real fix for that
这个答案有帮助吗?
得分 2
1条评论:
Yes, you're right! :-)
I'm gonna replacing the card reader.
Thank you for answer.
由完成的 分享
添加一条评论
I have a scan disk card as it was inserted into a card reader it was bent right in the middle. Can the data be recovered from it...it has several pictures and video on it?
这个答案有帮助吗?
得分 0
1条评论:
Stephanie, you will get much better help if you ask your own question and not tag it on as an answer to an old question. When you ask your question you should also give more info. Like the type of the card and where is it bend etc. Good luck
由完成的 分享
添加一条评论
I watched inside card reader.EverytDo I have to replace or remove it?hing staight up to bottomThank you I'm waiting for answer
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Taeyeon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 26
总计 6,109
