跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Camera 是一款使用 Android 操作系统的卡片相机。该相机具备 21 倍光学变焦和 1600 万像素的传感器,并支持 Wi-Fi、GPS 和蜂窝网络连接。
Can I replace my camera lens?
Accidentally dropped my EK-GC120 camera while I was trying to take a photo. Like salt on an open wound, it landed perfectly face down right on the camera lens as it was extended out. And now the lens itself does not close or open properly at all. I'm more than certain it's damaged permanently and cannot be fixed. My question is... Is there any possible way to replace just the camera lens itself? Or would I have to just buy a brand new one altogether? Cause the screen is still perfect, and all of the apps and features work properly except for the camera itself. I would just rather fix that then replace the whole thing if I can. Although, if it's cheaper to just buy a new one, that would be helpful to know as well. Please help...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
Yes ma. Camera lence is not workin
完成的
I had this camera over 2 years half I barely used it and yesterday I was taking a picture of my son with the flash and the red light come but the flash doesn't want to work anymore.
What do y'all think it's the problem?
完成的
I believe you should use the "ask a question" instead of asking a question into an unrelated issue, especially since this is the place for answers.
完成的
This page may answer your question. Why isn't the flash working?
完成的
添加一条评论
2个答案
已选择的解决方案
facedown018, use these instructions to replace your lens. Most replacement lenses will not come with the CCD, so remove it from your lens and transplant to the replacement.
这个答案有帮助吗?
得分 3
2条评论:
Instructions include:
"Most replacement lenses will not come with the CCD, so remove it from your lens and transplant to the replacement".
What is 'CCD' and how do you remove it?
完成的
@dck check the flex that goes from the motherboard to the lens you will see it terminates with the round part. Removing the flex from the lens will reveal the CCD sensor.
完成的
添加一条评论
You should be able to. I found a replacement set here, but no guarantee on part quality or ease of replacement. Also, this part doesn't include the CCD or lens housing either, so make sure you get all the parts you need. There are a few more options out there, but this one is pretty inexpensive. Have fun, and I hope you successfully fix it!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
facedown018 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 28
总计 2,920
