跳转到主内容
加入维修社区 - 创建账户
1997-2006 年生产的 TJ 系列牧马人(Wrangler)。
replace rear axle seal
remove right rear wheel axle
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
bob petrik,
Jack up Jeep, support with jack stands, remove rear wheels and brake drums
Remove diff cover
Remove cross shaft retaining bolt
Remove cross shaft
Push axle shafts in and remove C-clips from inner end
Gently slide axle shafts out of housing
Remove seals, being careful not to knock the rollers out of the bearings
Install new seals
Great information from here.
Here is a decent video about the procedure.
这个答案有帮助吗?
得分 3
2条评论:
Awesome information. I am new to all of this.... if I have a leaking seal, is there any reason that I couldn’t replace that without replacing the bearing?
由完成的 分享
The seal is separate from the bearing. There is no need to replace the bearing if it is still in good condition.
由完成的 分享
添加一条评论
添加你的答案
bob petrik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 10,360
