跳转到主内容
加入维修社区 - 创建账户
TI-84 Plus Silver Edition 是 2004 年发布的一款图形计算器。它配有 USB 端口、预装软件、应用程序 (APPS)、存储空间,以及可拆卸的前后外壳。
Flashing cursor on TI-84 Plus?
I haven't used my calculator since the AP Calc test, so I don't know specifically when it happened, but now when I turn it on, I can't do anything.
At first the screen just flashed "Ans^-1" (but the actual display of power of negative one) over and over, like I had selected it, but no matter what button I hit, nothing happened. I pulled out the batteries a couple times, waited half an hour, but nothing changed.
Then today I took out the backup battery as well, which did a little. Now it just flashes over an empty space, like when it's waiting for you to type the first number, but I still can't do anything with it. Help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Although this sounds like a hardware failure, you can try a software fix first.
Try to reinstall the OS. I don’t know if it’ll work for you since your keys aren’t functioning but you may as well try it anyways here. (Fun fact: the [on] key works because it’s hooked up to the calculator differently from all the other keys)
In the likely event that doesn’t work, refer to this guide for troubleshooting and hardware fixes.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
EJ 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 3,976
