跳转到主内容
加入维修社区 - 创建账户
2009 年推出的入门级 Photosmart 打印机。使用带有一次性打印头的惠普 (HP) 三色墨盒。
My printer wont scan.
It used to but now it won't. I also can't figure out how to reset up the wireless feature--it only funcions as a printer connected with USB to my computer.
Please help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
What computer are you connect to? What system are you running? When you did your last system upgrade did you go to HP and download the drivers for that system?
由完成的 分享
Thank you so much--reinstalling the drivers seemed to do the trick.
Aliza
由完成的 分享
添加一条评论
3个答案
已选择的解决方案
what operating systemhave you installed ?
maybe the drivers must be re-installed in order to use the scanner.
resetting the wifi should work like this:
1. Press the Scan button (it also the Wireless menu button)
2. Select Wireless Settings
3. Scroll down and select Restore Network Defaults. Press Yes to acknowledge
4. The radio will turn off (the blue LED will go out). Select Enable Wireless
5. Select WPS
6. Select Push Button
这个答案有帮助吗?
得分 4
8条评论:
+ Ralph
由完成的 分享
hi Ralph, thanks so much for your reply. It almost is working. When I get to stage 6, it's getting hung up, but I'll keep trying.
由完成的 分享
It is still getting hung up while searching for the wireless connection, even though I have one. Any other ideas?
由完成的 分享
i've read about problems with this printer and osx - since you didn't tell us whatt computer you have, i can only guess that you are also running osx. try adding the printer again - it helped many others with the scanning issue
由完成的 分享
Reinstalling the drivers seemed to ultimately do the trick. Thanks so much for your help!
Aliza
由完成的 分享
显示更多的3条评论
添加一条评论
All you need to do is try by going to HP.com website and find the latest and updated driver for your device. Un-install the existing driver and the install it with new fresh driver and scan software.
Hopefully this shall solve your problem.
这个答案有帮助吗?
得分 1
添加一条评论
Install the All-in-one driver for hp photosmart c4780; it worked for me. I had the same problem like everyone of you. it was really hard to find this solution. it was a trial and error solution, but it finally worked.
http://h10025.www1.hp.com/ewfrf/wc/produ...
这个答案有帮助吗?
得分 0
1条评论:
the original answer from almost two years ago says "the drivers must be re-installed in order to use the scanner" so pretty much the same thing that you are saying....:-)
由完成的 分享
添加一条评论
添加你的答案
Aliza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 27
总计 15,849
