跳转到主内容
A 7" tablet with a Android 4.2 (Jelly Bean) operating system.
Where I can get the firmware?
Hello, my tablet is bricked and not pass the logo of android, the firmware can not find it anywhere, I contacted the manufacturer but I do not want to provide the firmware.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 26
3条评论
I have rca tablet its google sync how can I by pass do I install new firmwarew if so how
完成的
My tablet will not power on so the screen is blank
完成的
como consigo el sofwer de RCA RCT6272W23
完成的
添加一条评论
8个答案
最有帮助的答案
I made firmware this AM that fixed both of my RCA rct6387w2 units. It may help you too, but it restores to factory so your data will be lost.
这个答案有帮助吗?
得分 11
4条评论:
Hello there.
I have the same problem.
The tablet doesn't pass the RCA logo
I hard reset it many times but its not result.
Can you help me?
完成的
where is this firmware
完成的
Can i get a link to a download for the firmware?
完成的
添加一条评论
hello how repain firmware this tabletRCA RCT6272W23
这个答案有帮助吗?
得分 2
1条评论:
Como yo actualizo mi tableta a la última versión
完成的
添加一条评论
Maybe look if Cyanogenmod is compatible.
这个答案有帮助吗?
得分 1
3条评论:
What is Cyanogenmod and where can it be found? Maybe give a link.
完成的
CyanogenMod is a modded android rom, http://www.cyanogenmod.org/
完成的
si pero cual es el cm que debo descargar
完成的
添加一条评论
Hi, after many hours into google, can´t find any ROM for this Tablet RCT6272W23
No luck with Rockchip Tools or BatchTools to erase NAND or flash another ROM all fails !!
Looking into FCC by the id in back , i find the HongKong manufacter, but no luck there.
Any info will be appreciated.
Regards
这个答案有帮助吗?
得分 0
添加一条评论
http://www.rockchipfirmware.com/sites/de...
这个答案有帮助吗?
得分 0
1条评论:
hola rommel mendieta: ese es el sofware de esta tablet RCA modelo RCT6272W23
完成的
添加一条评论
igual me pasa los mismo
这个答案有帮助吗?
得分 0
添加一条评论
Try factory reseting the tablet go in to recovery mode by holding the power and volume buttons
这个答案有帮助吗?
得分 0
添加一条评论
please post for link of firmware
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ernestogarcia95 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 23,013
