跳转到主内容
加入维修社区 - 创建账户
2007 年推出的 22 英寸 16:10 液晶显示器。在某些 Mac OS X 版本中,如果不进行校准,该显示器的色彩准确度可能会出现明显问题。
My monitor won't lite up
AL2216W monitor
My monitor won't lite up. The power button is lite (green) but no display.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Fixedit! changed the 5 caps, resurrect my 10 years old AL2216W!
由完成的
My caps are fine and the two boards are fine. It is the backlite that are gone. can someone tell mewhere to get the backlite replacement?
由完成的
Replaced the caps on two monitors and they work again. No power led when turned on.
由完成的
添加一条评论
2个答案
已选择的解决方案
Check the capacitors for swelling and/or corrosion: Acer AL2216W 电容更换
这个答案有帮助吗?
得分 3
8条评论:
I have bad capacitors in my AL2216W, too. Is this guide still available somewhere?
由完成的
I do not know why access is now forbidden. I'll link this question to someone at the iFixit staff and see if they can fix it! @kaykay
由完成的
Hi @mayer. That particular guide has been set to private by the author—looks like he might be working on improving it.
由完成的
Is it Nicks?
由完成的
Yup. Looks like he's been working on some edits.
由完成的
显示更多的3条评论
添加一条评论
Check for an image using a flashlight. If it's stable, then it's likely a bad backlight tube or capacitors. However, it’s generally a capacitor fault that can be salvaged with a complete recap of the power supply board.
If the capacitors look okay or a recap didn’t work, the problem usually lies with the power supply inverter or the CCFL tube in the panel. Sometimes this is fixed with a power supply, but it rarely fixes the problem when a recap doesn’t work. Mine lasted ~1 year with a recap and ended up with a failed backlight the second time (check for a black end on the tube). It’s generally difficult to replace this and you usually ruin the panel in the process if you never done it before.
The problem in your case is it's likely like mine where a new power supply won’t fix the problem because of a bad panel as the failure of the backlight is more unique - when the tube fails, you usually lose it within seconds while a capacitor failure is more gradual and doesn’t happen without warning. Since the panel is old, expensive and out of production, you’re better off recycling this and replacing it if the caps pass. Beyond attempting a capacitor replacement, it isn’t worth repairing the monitor.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
oscarpro 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 21
总计 4,086
