跳转到主内容
加入维修社区 - 创建账户
1984 年发布的 Quasar 微波炉维修指南,型号为 MQ7774XW。
will not run...cycles through numbers
When I plug it in...it starts beeping and the display says AUTO with DEF under it. But it is cycling thru numbers: 1.0, 2.0,3.0,4.0,5.0,6.0 then back to 1.0 and so on. Over and over and over
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Main Control Board
If the microwave display is not working the main control board is most likely defective and will need to be replaced.
Display Board
If the display has gone out the display board might be defective. If the display goes out completely the problem can be either the display board or the main control board. If the display goes out partially the problem is usually the display board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
mike w 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 583
