跳转到主内容
加入维修社区 - 创建账户
吊挂式叶片风扇的维修与支持。
How can I fix my ceiling fan?..
It makes a loud noise when its on and when it on actully it look like if its about to fall off
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
最有帮助的答案
Violet, not sure what it looks like but it does sound like your fan may be getting loose. Make sure that you fan is mouned on a fan-rated box and not just a box for a light fixture. It may came off where the box is mounted to in your ceiling. If that checks out okay you do want to check the screws that secure the blades to the motor. Make sure they are all tight. If none of those fixes solve the problem, try balancing the blades. Balancing kits are available at lighting stores.
这个答案有帮助吗?
得分 1
添加一条评论
Your ceiling fan has bearings in the motor that have to be oiled and that may be making the noise. What kind of noise is it? Grinding or wobbling? Also, you might want to check each blade to make sure that the screws have not come loose.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Violet 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 32
总计 2,559
