跳转到主内容
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
Black Spot on pictures
1/2" square black image appears on Lcd Monitor and in pictures. It looks like a piece of dirt on the lens but it will not wipe off, it must be on the inside.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
It looks like you solved your own problem right there in your question, they just confirmed your solution. :)
完成的
添加一条评论
3个答案
已选择的解决方案
We had an issue like this with one of the cameras here. Sure enough, as Majesty has said, it was a small speck of dirt on the sensor. Compressed air is a fine solution. They also make a cleaning solution for cameras for just this purpose as well.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
I would carefully open the camera up and clean the insides with compressed air. You might have dirt or other small debris on the sensor. Don not try to wipe the lens, most likely the debris is inside of the camera.
这个答案有帮助吗?
得分 3
添加一条评论
yes
clean the sensor(CCD)
10000% clear ur fault
i have clear this fault many time
这个答案有帮助吗?
得分 0
1条评论:
Keep up the repair solutions, but please do not post contact information to advertise your personal business. Thanks!
完成的
添加一条评论
添加你的答案
Ron Skelly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 5,024
