跳转到主内容
The Xiaomi Mi 3 is a high-end, premium Android smartphone that is produced by Xiaomi.
Any tips for replacing the charging port?
I want to replace the charging port as it is broken. Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
Hi Gaurav, I just want to ask, when you replaced the charging dock where there any components on it that you had to solder? Or was it a simple screw/unscrew replacement.
Thanks a lot!
完成的
Just un screw and replace a riblon that is gently glued
完成的
Hi Marcel, thank you so much for your assistance. One last question I promise and forgive my ignorance in the topic. Regarding the Xiomi mi3 charging docks, it seems that there are two options.
1)One with a mic on it (http://www.aliexpress.com/snapshot/68262...)
2)One without (http://www.ebay.com/itm/231518898672)
Not sure which I needed I ended up ordering both. Is the mic soldered? Which one should I use?
完成的
I want replace charging pot.I need open whole phone?
完成的
添加一条评论
2个答案
最有帮助的答案
Please check out the touch screen replacement manual as far as the usb ribbon is changed.
You may change it without the motherboard remove Step. So from Step 5 go directly to Step 9... It is easy.
You will find replacement part on aliexpress site.
这个答案有帮助吗?
得分 4
3条评论:
Hi I have the exact same problem where is this manual you are referring to? Could be kind enough to post me a link? Cheers
完成的
Thank you! It worked perfectly.
完成的
添加一条评论
Hi I have same problem
I was ordered this part 2 time from eBay but after replacing it.
No service
There is reception problem please guide me from which place original part will available
这个答案有帮助吗?
得分 1
1条评论:
Hi Guarav Narang Sir
Please help me about replacing this part
完成的
添加一条评论
添加你的答案
Gaurav 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 8,442
