跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Dropped my phone in water, screen flickering, what do I do?
Alright, so the other day I dropped my iPhone 5 into the toilet, but I immediately took it out and turned it off. I then proceeded to put it into a bag of rice for the next few days. Everything works perfectly, I can use it, speakers work, everything. However, there a slight problem, the screen flickers a lot. I have it on full brightness and it constantly seems as if I'm just sliding the brightness from the lowest to the brightest. Is there anything I can do to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
Alex Trevino, here is my answer to a similar question. "Rice does not work. IOt will not prevent corrosion! The very first thing you want to do is to stop using your phone. Stop right now and do not continue to charge or sync it. The very next step I would do is to disassemble it by following this guide. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. After that I would suggest that you clean it a couple of times in sterile water, not drinking water. Use a soft brush and clean it very, very thouroughly with the sterile water. Depending on the amount of corrosion, you may have to remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Also, I suggest to replace the lightning connector. The guide for that is here Yes, do replace the battery for sure. Use this guide for that. Keep in mind that water damage is the hardest to troubleshoot and to repair. the issue with your screen could be the LCD itself or the backlight circuitry on your logic board. Hope this helps, good luck.
iPhone图片
指南
修复iPhone 的进水故障
难度:
困难
1 - 2 hours
iPhone 5 电池图片
指南
iPhone 5 更换电池
难度:
中等
15 minutes - 1 hour
iPhone 5 逻辑板图片
指南
iPhone 5逻辑板更换
难度:
中等
1 - 2 hours
iPhone 5 尾插更换图片
指南
iPhone 5 尾插更换
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 0
添加一条评论
Dissassembling it will invalidate any warranties you have.
这个答案有帮助吗?
得分 0
1条评论:
the warranty cant do anything anyway when the iphone is water damaged. so in my humble opinion, just disassemble it, do wtv it takes so that you dont have to buy new iphone.
完成的
添加一条评论
添加你的答案
Alex Trevino 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 50
过去 30 天: 180
总计 55,524
