跳转到主内容
加入维修社区 - 创建账户
美味的水果。钾元素的良好来源。呈黄色。
How can I tell?
I can't tell if I have a banana or avocado or maybe a dog? I might even have a mink pelt. I just wish there was a way to see if what I was holding and attempting to eat is actually a banana.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 12
添加一条评论
5个答案
已选择的解决方案
In case you are blind, bring in a monkey, wait 5 minutes, feel for which item is missing.
这个答案有帮助吗?
得分 10
2条评论:
What if it were a plantain?
完成的
Then it wouldn't be a banana.
完成的
添加一条评论
Does the device emit a sound of any kind (while stationary)? Does it appear to have an on/off switch?
If it makes a sound, or has an on/off switch, it is NOT a banana.
这个答案有帮助吗?
得分 5
添加一条评论
is there a way you can post a picture of the device? it could be any of those. What are the specifications? or is it a knock off?
这个答案有帮助吗?
得分 3
添加一条评论
Bit in if it bits back it was the dog
这个答案有帮助吗?
得分 3
添加一条评论
Just make sure that the device is yellow and crescent moon shaped. If it has legs, then it's probably not edible in that state. If it's green, it may be an avocado. Hope this helps...
这个答案有帮助吗?
得分 2
4条评论:
if its green it also could be a cucumber, lime, or even a plantain. There are many options.
完成的
All of these green options are edible, however a lime is incredibly sour, and the anti-opening device in the lime will cause temporary blindness if the fluid is caught in the idea. A cucumber is extremely ovular. A plantain looks like a banana, but you may encounter bitterness. This is the anti-opening device.
完成的
the blindness will come from a lemon that has been died green.
完成的
That’s dyed green.
完成的
添加一条评论
添加你的答案
Yaxfer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 40
总计 1,215
