跳转到主内容
加入维修社区 - 创建账户
苹果第六代无线基站,于 2013 年 6 月发布。该塔式基站提供双频无线接入,是苹果首款采用 802.11ac 技术的路由器。
Thermal pad replacement comments?
I took my AirPort Extreme apart to give it a clean because it was full of dust. I thought I would remove the heat sinks just for interests sake. When I removed the heat sink I noticed it had a thermal pad between the sink and the Broadcom router chip. I was a little disappointed this was not mentioned in any of the tear downs as I like to replace thermal pads when I pull things apart. I had to put it back together as was but I am looking to replace the thermal pad. Does anyone have any suggestions? Also any suggestions on pad thickness? I was thinking 3mm from memory. IT seemed like a fairly big gap from memory. Any comments greatly appreciated. Also from memory there was definitely only one thermal pad yes?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
These might work for you:
https://www.ebay.com/i/302812527840?chn=...
maybe these
https://www.amazon.com/Fujipoly-Extreme-...
or maybe one of these:
https://www.amazon.com/s/?ie=UTF8&keywor...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
opinio 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 32
总计 549
