跳转到主内容
The HP Chromebook 14 is a variant of the Google Chromebook line released September 11, 2013. Model number is 14-Q010DX.
Why does my sound not work?
So today I went to turn on my chromebook, but the sound was not working. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 280
26条评论
Thx soo much the site fixed my sound! Love this site!!
完成的
OMG TYSM IT ACCTUALY WORKED YOU R A LIFE SAVOR!!!!!! im gonna rate it auwsome. i litterally came back in figure it worked and looked the same thing up again and made an account just to tell u thank u sooo much i was sooo scared..
完成的
My volume control does work to volume up or down. No control!
I get sound but no volume adjustment.
完成的
it did not work for my boy daylan
完成的
me too, new computer
完成的
显示更多的21条评论
添加一条评论
11个答案
已选择的解决方案
Try to shut down and go to settings press volume and mute it then shut down once more and turn it up it worked for me so good luck Bradon Nolen
这个答案有帮助吗?
得分 149
110条评论:
Genius! Thank you, thank you, thank you.
完成的
Thank you so much!!! I thought I had broken the sound, but no! I'm so happy!!
完成的
thank you so much you helped so much i thought i was going to die thank you once again
完成的
this doesn't work on my chromebook and I am not happy :(
完成的
I did it and I cant believe it worked i was so surprised thank you so much.
完成的
显示更多的105条评论
添加一条评论
No sound could be several things:
First: Check that the earphone/external plug is fully plugged in. Then go to the lower right hand corner, to the volume control and click on the arrow > and make sure that your device (headphones etc) is selected. If it just says input | output, make sure your Chromebook is charged. My audio buttons quit working and the volume bar stays to the left when my battery gets too low. Charge it up and then do a browser reset and a hard reset. (to do the browser reset, click the three bars in the upper right hand corner, go to settings>advanced settings >browser reset (at the bottom). Then hold the refresh button (looks like a circle with an arrow, usually the F3) and the power. This generally does the trick for me.
这个答案有帮助吗?
得分 15
7条评论:
Thank you. Holding down the refresh button and the power button did the trick for me. Thank you for your help. None of the other ones worked for me!
完成的
i have a chrome book
完成的
I also have a chrome book
完成的
I clicked yes by accident and I need help because I tried everything and it still won't work and btw i'm a kid
完成的
Worked for me. Thanks
完成的
显示更多的2条评论
添加一条评论
The same thing happened to me where my top row keys wouldn't function, including the volume and brightness keys. I tried the shut down process, and it didn't work. When I checked settings and went to keyboard, I realized I had pressed "Treat top-row keys as function keys." After I unchecked it, all the keys worked again.
这个答案有帮助吗?
得分 14
5条评论:
omg thank you this was the only one out of like 15 that worked
完成的
oml thank you so much for this! I checked settings and I didn't see the option "Treat top-row keys as function keys" and I got so annoyed but then I checked it again and saw the option. I said "Oml thank god." I am only 10 years old and I thought I broke my chromebook and my parents would have been so mad if I did, but thanks to you I realized I didn't. Thank you so much :)
完成的
yep my top row was set to function keys....which i still don't know how to use
完成的
Thanks so much...yep same thing happened to me...would never have figured it out without you. Thanks again!
完成的
My sound wont work and I dont wanna pay 400 for this computer. Its a chromebook and I mute and unmute but the sound wont work.
完成的
添加一条评论
If you are using a laptop computer with no external speakers connected, make sure the volume is turned up by using controls on the keyboard. They may buttons (as shown in the image to the right), or a secondary function of another key; generally indicated with blue text and activated by holding the Fn key at the same time.
这个答案有帮助吗?
得分 4
添加一条评论
I had this same problem but am pretty sure I fixed it by pushing the M key which un mutes it
这个答案有帮助吗?
得分 3
添加一条评论
I plugged in my earbuds, played my music for 5 or more seconds, paused, unplugged the earbuds and pressed play, it worked.
这个答案有帮助吗?
得分 3
1条评论:
you are dum
完成的
添加一条评论
Click on your settings. Next to the adjustable volume you might see a pair of earbuds. Click on the earbuds and go to the output section. Finally click speaker> i hope this helped ;)
这个答案有帮助吗?
得分 2
3条评论:
it didn't work
完成的
I am on a Chromebook it does not have a pair of headphones
完成的
I have a pair of headphones and I had to unplug it and It worked
完成的
添加一条评论
I have a Chromebook and i was logged in to my account and my sound was not working so I logged in as guest and it worked probably because I installed a chrome app that did that.
这个答案有帮助吗?
得分 2
添加一条评论
My sound wasn’t working for me but it turns out my earbuds were broken. So I plugged in new earbuds and it worked great! If your sound isn’t working try different earbuds/headphones. I hope this helps!
这个答案有帮助吗?
得分 1
添加一条评论
I had this problem to it could be a whole computer issue or could just be this. so use two fingers and click on the tab and then go down to under pin if it says unmute site then that the problem you just muted the site if it say mute site then sorry it’s something else
这个答案有帮助吗?
得分 0
添加一条评论
Sound may not work due to muted volume, faulty drivers, disconnected speakers, the wrong output device, or hardware issues. Check sound settings, update drivers, and ensure cables or Bluetooth are connected.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon Nolen 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 15
过去 30 天: 52
总计 198,757
