跳转到主内容
加入维修社区 - 创建账户
7.9 英寸显示屏 / 型号 A1454 / 有黑色或白色可选 / 2012 年 10 月 23 日发布 / 16、32 或 64 GB 容量
Restoring a jail broken ipad
my iPad was jail broken, I would like to restore to its original state
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi Peter,
- Backup: back-up your data using iTunes, and as an added measure, manually copy your photos and contacts(or anything you deem important) to your laptop using iPhoto and/or iFunbox for example. Or sync everything with iCloud. I say that because sometimes backed-up data of jailbroken devices is corrupted and cannot be restored.
- Restore mode: turn off your iPad. Connect it to your laptop. Start iTunes on your laptop. Now press and hold power button + home button together for ~12 seconds, then release power button but keep pressing home button for ~15 seconds. iTunes should now say it detected an iPad in restore mode and prompt you to download and install the latest software. Accept, and leave your iPad connected and undisturbed until it finishes the download and restore which could take long if you have a slow Internet connection (the file is ~1.5GB).
- Once done, your iPad will restart with the new firmware. You can choose at this point to restore the back-up or manually syncing data back to your iPad.
Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Peter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 26
总计 634
