screen touch does not work after replacement?
I replaced the screen and digitizer and the screen comes on but touch doesn't work. I've checked all connections twice. What could it be?
jeyson, if you are sure that all your connections are properly seated, I would contact the vendor and replace the assembly once more. Sadly enough, it is not uncommon to receive a bad digitizer. Of course, you always want to double check your work, check to make sure that there are no bend or broken pins on the connector.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 26
总计 1,626
3条评论
Jeyson......did you end up fixing this problem??
由 Jason Gonzalez 完成的
I have the same issue. My ZTE zmax pro z981 screen broke and I bought 2 new screens and after I put new screen it lights up but doesnt respond to any commands
由 Nikola Tesla 完成的
I have the same problem except mine's a ZTE n9521 screen not responding to touch
由 br700973 完成的
