跳转到主内容
加入维修社区 - 创建账户
Wii U 是任天堂推出的一款游戏主机,配有一台名为 GamePad 的手持设备,允许用户通过 GamePad 游玩游戏。该主机的维修非常简单,因为设备采用了高度模块化的设计。
Replacement ribbon cable clamp?
So today I decided to replace my gamepad screen, since my old one had a scratch that make a area of the screen untouchable. Seems while in the process one of the ribbon clamps came off.
here it is.
I found it, but while trying to put it back on it snapped in half. it looks like this one.
Here.
Anyone know if (and where) I can find a replacement, or a way to make it work? Everything works fine except for touch, which is what this cable is for. I hear electrical tape can work, but I don't know what exactly to do with that.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
已选择的解决方案
Position the ribbon cable onto the conector and then use white tak...its like blue tak but kind of sets harder!...to keep the cable pressed down.
This worked for my one!
You might have to try a couple of times before you get it to work!
Take a look at my YouTube video...
https://m.youtube.com/watch?v=mNbxeLlpaO...
http://www.amazon.co.uk/WHITE-TACK-BLUE-...
这个答案有帮助吗?
得分 1
5条评论:
Would love to see this youtube video. I just tried and got nothing :/ Is the ribbon supposed to lay on top of the connector, or under? It slips in under so i figured thats the right way to do it.
由完成的
Just doing my vid today... i'll post on YouTube tomorrow and I posted the link asap.
由完成的
Awesome, thanks!
由完成的
great solution, thanks!
由完成的
添加一条评论
最有帮助的答案
The ribbon cable socket is desoldered from the logic board. It can be soldered in place but this have to be done by a pro. Find a place that repair iPhones and ask them to do the job.
这个答案有帮助吗?
得分 2
8条评论:
Isn't the socket what the ribbon cable goes into? I'm just talking about the gray thing that clamps down on it, unless that's what you're talking about.
由完成的
OK, doublechecking at the first pict I think that it's the cable that need to be replaced. The connector is desoldered from the cable and seat now in the socket. Not sure that the connector can be soldered to the cable.
由完成的
Looks more like the grey clasp is broken off. It provides downward pressure on the cable and allows it to make contact.
由完成的
oldturkey, is it the same type of socket than the keyboard backlight socket on a MBP ? You insert the cable in it and push down a lever to secure the cable ?
由完成的
The cable's fine, the angle just makes it look weird. I am talking about the gray part that clamps down for pressure.
由完成的
显示更多的3条评论
添加一条评论
I need this answer too. Chrisall76 did you ever get something to work?
这个答案有帮助吗?
得分 0
1条评论:
Nope, had to buy a new gamepad.
由完成的
添加一条评论
Does electrical tape work?
这个答案有帮助吗?
得分 0
1条评论:
i taped it with gorilla tape... but when i had to replace the touch screen the tape didnt work anymore.... im trying hot glue next
由完成的
添加一条评论
i did the same to the clasp that is for video....the one in your second pic. i put tape on it....keeps going off. i started to put hard things on top of the ribbon with tape for pressure and still comes off. some said glue but i dont like that idea because one it can cover the pins and two what if you need to replace stuff and it cant come out. i was wondering if the clasp was replaceable too
这个答案有帮助吗?
得分 0
1条评论:
Fixed this whith white tak...
由完成的
添加一条评论
添加你的答案
chrisall76 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 40
总计 12,315
