跳转到主内容
加入维修社区 - 创建账户
这是一款由三星公司制造并于2012年8月22日发布的三星手机。
How do you fix water damage?
I was with my friend and they pushed me into there pool and my phone was IN MY POCKET!!!!! Now it is all wet and I don't know what to do. Please help!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
First of all dry the phone thoroughly with a dry cloth. Take out the battery and dry it as well. DO NOT put the battery back in the phone and try to power it on. Now get a bowl and fill it with enough rice to cover the entire phone. Put the phone in the rice until it is complete covered and put the battery in the rice also. Wait at least 24 hours before putting the battery back in the phone. Power it on and hope for the best.
这个答案有帮助吗?
得分 0
添加一条评论
Kasey, skip the rice. The "rice trick" is one big myth. Placing your phone in rice is equivalent to doing nothing. It does not prevent any kind of corrosion or fixes your phone. The best thing to do is to stop using the device, (remove the battery) and to totally disassemble it. Then clean it with +90% isopropyl alcohol. This will displace the water and stop corrosion. It it okay to submerge a board in isopropyl alcohol. Check this guide to show you how to do it. It was written for an iPhone but all the points are still pertinent to your phone as well. After that, air dry all the components. Do not forget to clean the connectors on the board as well as the cables. Then re-assemble with a new battery This is not optional but a must to avoid failure later on. " Check your board for any missing or damaged component. Water damage is the toughest to trouble shoot and to repair. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kasey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 543
