跳转到主内容
加入维修社区 - 创建账户
Western Digital My Passport 硬盘。USB 3.0 便携式外置硬盘。
My passport fails initializing
My passport 1TB ran for more than a year under windows 7,8 and actually 8.1, but suddenly stopped. it loads the drivers but doesn't appear in the explorer. when I start the disk management it indicates that the second disk (my passport) must initialize. but it fails.
it appears in the device windows , just doesn't start (or initialize). I even tried the refrigerator trick, nothing
I've also tried several data recover progs, recuva , testdisk, easyus, wondershare WAC, etc, they all fail to see the external drive.
there must be a program that can go through , any ideas?
thanks, Jim
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 20
6条评论
Just tried R-Studio, it sees the disk, but cant read it
由完成的 分享
I was able to see the data inside the HDD with a linux version included in the Hiren's 15.2 CD also i could copy some files I needed but with 0 KB no luck yet, still working on it.
由完成的 分享
2tb western digital my book, same problem, R-Studio brings up error 1117. Spent 3 days now trying to recover
由完成的 分享
This problem is also with me too
由完成的 分享
Hello, one could solve it?
由完成的 分享
显示更多的1条评论
添加一条评论
8个答案
已选择的解决方案
This may still be true. Try wiping the drive on a Mac and use the "write zeros" option. Used to be that if the boot blocks on an IBM went bad it was unusable with Windows but can be fixed on a Mac.
这个答案有帮助吗?
得分 2
2条评论:
there was some data that I would have liked to recover there. but if there's no other way. will try it as a last option. tnxz
由完成的 分享
@mayer I fear that won't work on a Passport. These are custom amalgamations of a SATA and USB port. The enclosure itself is the drive. You can't even take it out and put it in another enclosure.
由完成的 分享
添加一条评论
The only 2 possible suggestions that may work are:
a) Solder on a new USB port.
b) Find a logic board for the matching drive. Hopefully you can find one with a SATA connection.
If you can get a working SATA port, then recovering may be possible.
这个答案有帮助吗?
得分 1
添加一条评论
this problem can't fix by any software...
you must repair the hardware of your WD HDD !!!
这个答案有帮助吗?
得分 0
添加一条评论
HOW can I repair hardware in a hdd??!! You need highly specialized equipment
这个答案有帮助吗?
得分 0
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
same whith me sombody can help please?
Thank you
这个答案有帮助吗?
得分 0
添加一条评论
Hi Everyone,
this problem is because of firmware corruption of WD Hard disk drive that must be solve by Hard Repair Equipment like a PC3K ( a expensive hard repair hardware! ) but you can give your Western Digital hard disk to a HDD Data Recovery company to bring the information to you and do a hard repair for your precious Hard Disk.
i have that equipment and can do for you without any cost dear,
Hard Repair Company in IRAN
这个答案有帮助吗?
得分 0
2条评论:
Right! We are going to send our HDD s with our data to IRAN!
由完成的 分享
Yes dear,
We will repair your Hard disk without any cost
由完成的 分享
添加一条评论
Try WD SmatWare Installer. if you can get to where it asks for Password type in 5 wrong answers it will then ask if you want to reformat say yes and you will lose all data on the drive but have the drive initialized and back working.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jimlberto 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 47
总计 30,763
