跳转到主内容
The Lenovo IdeaPad U350 was released in 2009 as a low-cost, thin, light laptop. It shipped with Windows Vista Home Premium (64-bit) or Ubuntu and features a 13.3" display.
Why is my laptop randomly shutting itself off?
Lately my IdeaPad U350 has been shutting itself down without any prompt or notification. It's not the normal Windows shutdown, either. The screen just goes black and it turns off immediately. Sometimes it will work for an hour before this happens, and sometimes less. I noticed that if I let it sit off for a while between shutdowns, it will last a bit longer. Any help is appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 31
66条评论
Hi,
I have the same issue . I have a Lenovo ideapad flex 10, which shuts down automatically whether on power or not and whether idle or not.
Please help.
完成的
Hi,
I too have the same issue . I have a Lenovo ideapad S510p, which shuts down automatically whether on power or not and whether idle or not.
Please help.
完成的
I have a Lenovo think pad and i can get it to run for 15 minutes and then it turns itself off even in bios bit it takes longer in bios. I tried to run a test to see if its the motherboard and i couldn't even get the test to finish to see. I have it plugged in and it still turns off. Battery was replaced a year ago. Now my laptop is a nice paperweight.
完成的
I have Lenovo G560 Iam play 5 min game and the PC is turns off pls help me.
SORRY FOR MY BAD ENGLISH IAM FROM CZECH REPUBLIC
完成的
I have a Lenovo Yoga 3 14" and have just started having the same issue. Only happens when on battery, and my fan is working.
完成的
显示更多的61条评论
添加一条评论
8个答案
已选择的解决方案
The following solved it for me....
To do it via the Power Options, right click the battery icon (or electrical plug icon) in the lower left corner of the screen, then...
1. Select a power plan and then click "Change plan settings"
2. Click "Change Advanced Power Settings"
3. Look for "Processor power management" and expand it
4. Expand "Maximum processor state"
You can now enter the percentage usage of the CPU while on battery and plugged in.
Note that it does not work the way you think it would work. Meaning if you set the CPU to 90% it will run at 90% of the stock clockspeed. No... it's not like that. For example, my i5-2410m has a stock speed of 2.3GHz. Turbo boost overclocks it to as high as 2.9GHz when stressed.
100% = Turbo Boost on.
99% = Turbo Boost off. CPU runs at 2.3GHz
78% - 98% = 1.796GHz
69% - 77% = 1.596GHz
60% - 68% = 1.397GHz
So you get the picture.
这个答案有帮助吗?
得分 21
12条评论:
Thank you times a million for posting your solution!! I was so frustrated that my brand new laptop was shutting off but I haven't had a problem in months thanks to this fix!
完成的
Er... sorry for the dumb question, but what % are you meant to set the maximum processor state to? I've tried 99%, 100% and 90%, and I've still had my Lenovo Yoga 910 (windows 10) black-screen on me 3x in the past hour. (I had set it to 99% before because that reduced the fan noise problem.)
完成的
Thank you for taking the time to type the instructions. I do not understand how to know which % to select? Do I want turbo boost off? On? Do I set it low?
完成的
Thank you for the information!! I have the same problem. I would like to know what is the correct % I have to choose?
Thank you!
完成的
does this also work with acer windows??????
完成的
显示更多的7条评论
添加一条评论
It sounds like your laptop is overheating. The first thing to test is making sure that your fan is working. If you don't hear it and can't feel any airflow from the exhaust vent, then either your fan or your laptop's fan controller (which is located on the motherboard) is broken. If your fan is working, then the thermal paste between the CPU and the heatsink likely isn't transferring heat properly. Fixing this will require disassembling your laptop and applying new thermal paste. I recommend Arctic Silver 5 or Noctua NT-H1 thermal paste.
这个答案有帮助吗?
得分 9
1条评论:
Thanks a million. I have some clue now.
完成的
添加一条评论
Reasons Your Laptop Suddenly Shuts Off
Dirty Fan/Overheating
One of the first and the most likely reason your computer or laptop shuts off randomly, especially when you’re playing a game, is overheating. This is the bane of most computers, especially laptops, since the heat has nowhere to go. It is critical that the computer’s fans are excellent working order to avoid this issue.
Hardware Failure
Another common reason for a random shut down of your computer is a hardware component failure, which is not unheard of, especially on computers that have been refurbished. If you’ve recently added any new hardware this is the time to remove it to see if the shut down issue goes away.
Overclocked CPU Or GPU
If you have enabled overclocking on your computer, it may cause your computer to become unstable when used for more intense activities like gaming or video processing. This problem can be a tough one to verify.
Your best bet would be to ensure that overclocking is disabled on your laptop or PC and then see if that stops the laptop randomly turning off incidents.
Outdated, Missing Or Crashing Device Drivers
Often, the problem with a hardware component causing issues is not the hardware itself but the accompanying driver. Incompatible drivers can cause all sorts of problems. If you’ve tinkered with your operating system or have changed drivers on your computer, this too can be troublesome. A driver crash can always completely shut down a computer.
Computer Virus
A more rare cause of a computer shutting down randomly can be a computer virus. Some computer viruses will actually shut off your computer, and then turn it back on.
These viruses are usually activated by a certain thing you do on a computer, whether it’s a keystroke or opening a particular program. To make sure you have your best defenses up against viruses, make sure you’re running a great background anti-virus program like Malwarebytes, and that you regularly update the virus definitions and scan your computer.
A Faulty Charger, Battery Or Power Supply
If you’re a gamer and your laptop shuts off randomly while you’re playing a game at the usual performance setting, chances are it’s your charger/power source.
Most devices come with specific ratings of the chargers that are meant to be used with the device. Using a lower voltage or higher current adapter can cause your device to not work properly and even shut down.
Enabled Fast Startup In Windows
The Fast Startup feature is aimed to reduce the booting time of a computer after it has been shut down, but it can cause Windows 10 random shutdown issues. Having this feature enabled on your computer, Windows will close all the applications and log off all the users just like it would do for a normal shutdown.
However, before the shutdown completes, the current system state gets saved in the hibernation file. When you boot your PC, Windows doesn’t need to load the kernel, system files, and drivers again. Windows reads the hibernation file to refresh the RAM and significantly reduces the boot up time.
A Lack Of Service
Though computers are usually sturdy, they may at times require proper maintenance. Without getting a service,  laptops may run into overheating, performance and even battery problems.
Get your laptop serviced by a professional to eliminate most of the issues related to your laptop including the computer keeps shutting down problems and any other performance issues.
这个答案有帮助吗?
得分 6
添加一条评论
I have a lenovo x220 and had the same problem. Altough I checked the temp and it wasn’t excessive I have just changed the thermal paste and it has been working for 5 hours without shutting down. Before I couldn’t use it for 20 minutes and afterwards it kept shutting down all the time, even when idle even in the bios. I found a forum thread where this was the solution for many people with the same lenovo.
Techs will tell you to change the motherboard. But it seems that this worked out for many people with this problem.
这个答案有帮助吗?
得分 4
2条评论:
I've done the same thing to 3 or so laptops that were having stability problems like this. It makes an incredible difference. One of them would show the Core 2 Duo going to 90 degrees and then it would shut off, another would do it during CPU intense things and Windows update
I think a good indicator is to watch the CPU temps, idling at 60C is a bit high, even for laptops. After changing thermal paste it would drop down to 45-50c and jump to 70c max under load
完成的
My CPU temp was fine when measuring,
but still that was the solution Had been looking forever
完成的
添加一条评论
Another way that should work: right-click the mini power icon on one end of your taskbar. Select Power Options. This will open a window with power settings in Control Panel. Select a plan. (with the newest w10 there should just be one unless you have a custom because it is programmed to be adjustable (balanced)). Click change lan settings then click change advanced power settings. In the new power settings popup expand hard disk and then expand turn off hard disk after and click the down arrow until it says "Never" do this for both battery and when plugged in. this is the solution i found after reading the original answer to this issue.
这个答案有帮助吗?
得分 2
4条评论:
you dont have to mess with the processor at all bc thats not what is crashing
完成的
the hard disk is just automatically shutting down on default w10 settings (why is that default on only some?)
完成的
I did not find the last option 'never'.
完成的
^^ last option is location when you press the up arrow button then back down to "0", press the down button again and it will say "never".
完成的
添加一条评论
I fixed mine by replacing the cooling paste never drops out anymore. It shut down every 5 minutes.
这个答案有帮助吗?
得分 1
1条评论:
In my case, something related to similar lines ..
In Power Options, Advanced Power Settings, "Balanced" power profile was active.
It was strange to see under this option... Processor cooling policy - On battery as "Passive", and Plugged in as Active.
Now I changed : "on battery" option from "Passive" to "Active".
I will keep watch on this now on.. Let me see how it goes !
完成的
添加一条评论
Not really solve the issue on my side but upon reducing power consumption items like removing my headset and change to a normal mouse (not gaming mouse), then turning off my screen doesn’t show anymore
这个答案有帮助吗?
得分 0
添加一条评论
I have a Lenovo IdeaPad U310. After about an hour it turns itself off. There is a new SSD and windows 10 x64. It has current drivers. The processors are at a temperature of 50 degrees. The laptop seems fine, but it doesn't overheat, but it still shuts down. It also shuts off outside of memory, for example during a memory test. I use Memtest. Does anyone have an idea?
这个答案有帮助吗?
得分 0
2条评论:
Hi,
Does it do this when the charger is connected or when on the battery only?
How long is it on for before it shuts down?
If it stays on for long enough, try creating a Win 10 battery report and check the status of the battery, just to eliminate it as a possibility.
完成的
I tried disconnecting the battery from the motherboard and using only mains power. The problem is still there, I have no ideas anymore and I think there is a problem with the motherboard.
完成的
添加一条评论
添加你的答案
Jason Sweeney 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 39
过去 30 天: 187
总计 227,275
